12-09-2024 08:10 PM - last edited on 12-09-2024 10:30 PM by computergeek541
Im in the us ..with can /us ulimited plan but unabble to call out any were ..was working for a month and a half .....tryed T-mobile /AT@T/VERIZON/313100 ...AND nothing
a month ago
Well kinda.. the problem has been solved. Things worked for about a month that we have been
12-10-2024 09:30 AM - edited 12-10-2024 09:31 AM
@Kim34 both phones are on auto connect ...and are on lte/wcdma/gsm
About the only thing you can try is to take it off auto and set it to 2G if you have that option, and manually try T-Mobile. If there's no T-Mobile 2G in your area then you're pretty much left with a voip app like TextNow or Fongo for voice calls (they will work with data or wifi but the downside is you'd have a second phone number) . In the USA a phone needs to have VoLTE (voice over lte) because they have no more 3G networks there since 2022 and a non-VoLTE phone needs to use 3G for phone calls as it can't make them over LTE. Everyone in the USA had to replace their phones if the ones they had were not VoLTE capable or approved by their US carrier.
12-10-2024 09:24 AM
12-10-2024 09:20 AM
hi @Kim34
both S9+ and S20 ultra are not VoLTE compatible with PM network
so, for voice, your choice would be to use app like Whatsapp to make calls or use VoIP app like TextNow. TextNow will give you another 10 digits number so people can call you like regular phone and you just use TextNow to receive and make calls with your data connection (or Wifi)
12-10-2024 09:17 AM
all data works ....its just the voice calls ...both of our phones are doing the same thing ..we can not call out ( it gos through all the motions but will not connect.) the phones are a (galaxy s9+) and ( S20 ultra ) data roaming is turned on in the phone.
12-10-2024 08:00 AM
@Kim34 Is nothing working, or is it just voice calls? If it's a non-VoLTE issue your texts and data should still work. If your phone is not VoLTE capable or approved yet it worked for a month and a half you may have been on T-Mobile's 2G service but it is being, or has been, shut down as of September 1st. Perhaps it is being decommissioned at different times in different areas. We can help more if you tell us what phone you have. Try T-Mobile again with the phone set to 2G (or 3G if you don't have 2G since some phones seem able to connect to 2G if set to 3G) and see if it will connect. Also it shouldn't make any difference to voice calls but make sure data roaming is turned on in the phone.
12-09-2024 09:22 PM
What phone do you have? Possibly it's not VoLTE compatible with Public Mobile, as noted above.
Also just a side note, but none of the roaming plans offer unlimited data. If you're referring to unlimited calling, that is true.
12-09-2024 08:14 PM - edited 12-09-2024 08:19 PM
@Kim34 Try phone set to 4G/LTE not 5G and try the different roaming partners again see if that helps , also note if your phone is not on the PM voLTE whitelist making calls will be difficult and you have to rely on phone set to 2G/3G and connect to T mobile if that doesn’t work you can download text now app or what’s app for voice calls
VoLTE white list
