11-09-2019 05:45 PM - edited 01-05-2022 07:55 AM
Just bought 25$ call and text and checked my account the payment went through and said pay again on the 9th of dec but says I need a a long distance add on?? Been buying for last 6 months and never had this happen
11-09-2019 06:39 PM
@Brandon2 Restart your phone and try again. If you still can't make a call and your device is compatible with the Public network then submit a ticket for further investigation.
11-09-2019 06:33 PM
@Brandon2 wrote:Just bought 25$ call and text and checked my account the payment went through and said pay again on the 9th of dec but says I need a a long distance add on?? Been buying for last 6 months and never had this happen
If this was your plan for the last 6 months...something didn't get provisioned properly during the renewal. Try rebooting the phone. If that doesn't clear things up, you'll have to click on the ? in lower right side of the page to start the process of contacting a moderator.
Good luck.
11-09-2019 06:27 PM
More details may be helpful.
Is your account status active or suspended?
Does text and data work? Incoming calls?
11-09-2019 05:54 PM
I'm assuming it's doing that when you're trying to call another Canadian phone number? Is it all numbers it's doing that for?
