Long Distance
diger
local calls work BUT Long distance does NOT please help
Hi @diger it is weird, almost like a device problem as it works on another phone but just this one
submit a ticket with PM CS agent and see what they say
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
diger
Did all that Message comes Mobile Network Unavailable
hi @diger
put it back to the original phone, does it work now?
If still not work, click Reset All Network, test again
diger
Yes I used the 1 and I have Canada Wide and the simm works with a different phone
hi @diger did you put a 1 in front of the 10 digits number?
and your have Canada wide calling Plan? most plan should have that
