sort Out my challenge
Rodriguez
hi! Have an issue about my sim unfortunately before I started use it, I never registered it under my name, so what can I do to register under my identity???
2 REPLIES 2
NDesai
@Rodriguez Are you saying that the current PM SIM you use is registered under someone else's name? If yes, you will have to prove it is your account. I am not sure if the name can be changed, but you can try contacting PM CS Agent if that is what you are tying to do.
Here’s when and how to contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
Hi @Rodriguez you got a new sim card  for your existing PM account?  Login to My Account using Desktop and go to Profile page to request Change sim card there
