Login
Whit4d
It says to many login attemps. So what do i do now?
@Meow wrote:
Try in a hour or so and use incognito/private browser mode.
Do NOT change password. If you do, wait 20min to attempt to log in.
There's no need to wait an hour before trying again, and there's also no 20 minute delay after changing passwords.  After clearing the cache, clearing the cookies, closing, and resarting the browser (or using the mentioned incognito mode), Self Serve will accept more login attempts immediately.
Meow
hycm53
Wait for one hour, then try again.
But this time you should use private or incognito mode to login, try use computer to login.
@Whit4d   just close the browser and relaunch and try again
you can also try to use Incognito mode
will13am
@Whit4d , try login again using incognito mode on the browser.
