12-05-2022 05:49 PM
When I try to login in, it keeps giving me
Email or password is incorrect. Please try again, or reset password.
I did a reset password and tried to log in, gives me the same.
12-05-2022 06:11 PM
@Techie many confirmed they can login after couple attempts
If you are in no rush, try back in an hour
But if you really need it now, then try again, and again 🙂
12-05-2022 06:10 PM
I have the exact same issue. Msg comes back from PM: “system error please try again”
12-05-2022 05:56 PM
Don't try to log in in next few hours and do NOT change your password. It is not you, PM has some issues.
12-05-2022 05:55 PM
@mcallist66 it could work if you try again couple times
So, maybe there are couple servers and one or two are now down. You might be able to login if it routes you to the good one
12-05-2022 05:51 PM
@mcallist66 couple of us have problem logging on to it in the last 5 to 10 minutes It has been on and off
you can try to use Incognito mode
If you do not need to do anything urgent, maybe wait and try back in an hour.
