Login to account
Jrmorris
After I set up an account and a password I was unable to log back in. For days now I am trying to change my password but am receiving the same annoying message that the password cannot be changed at thus time.  Who can get the system to respond to my request!!!
HI @Jrmorris   if you got the message about you cannot reset password at this time, then something is wrong with your account.
Please submit a ticket with CS agent and let them help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
@Jrmorris  Get support to help you regain access
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
@Jrmorris   what was the error that you cannot login to My Account?  just incorrect password?
try to use Incognito mode to login once and see if it works
If not,  PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
