Log in
Amy31
Unable to log into the app to complete the activation process.  Keeps sending codes to email, I enter the code and it takes me back to log in screen.  I’ve tried several times without success.
porcupine
Click on the envelope in the bottom right corner and follow the prompts to get help
slusagm
you will need PM to help for the app login to complete the activation.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
