12-30-2022 10:32 AM
I cannot log into my account. Only community. Will not allow me to reset my password as well
12-30-2022 11:04 AM
tried all that not accepting anything
12-30-2022 11:03 AM
tried all that waiting on ticket
12-30-2022 10:40 AM
HI @LG28 yes, Community and My Account are different system different login
if you are unable to login now and reset password , please work with CS agent for a password reset
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
12-30-2022 10:38 AM
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-30-2022 10:37 AM - edited 12-30-2022 10:39 AM
When logging in using mobile, if using chrome, once your saved credentials are populating the necessary fields, don't tap any further buttons and let the system automatically log you in.
Chrome has a way of doing this and if you tap anything after those credentials are populated, it will produce an error message and not allow you to log in.
12-30-2022 10:35 AM
Try logging into your account using a different browser in incognito or private mode instead.
Try again.
12-30-2022 10:33 AM
@LG28 wrote:I cannot log into my account. Only community. Will not allow me to reset my password as well
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to login. For some mysteriously reasons, mobile device some times hard to login, so don't use mobile device to login.
Follow above method try login again.
Chat with Simon for help, if Simon can’t help, he would let you submit a ticket.
https://www.publicmobile.ca/en/on/get-help
