07-13-2022 05:48 PM
Tried numerous times to login and failed, now it says to many attempts and cannot access account
Community
07-13-2022 06:10 PM
Ok thank you
07-13-2022 06:06 PM
Community account
07-13-2022 06:06 PM
What are the links?
07-13-2022 06:05 PM
Ok thank you
07-13-2022 06:04 PM
Yes account is active and did enter correct info
07-13-2022 05:57 PM
@jay18 wrote:Tried numerous times to login and failed, now it says to many attempts and cannot access account
@jay18 - has your account been in active status within 90 days?
If you have been in nonpay/suspended status for over 90 days, then you lost your Public Mobile account, phone number, and access to self serve.
Otherwise, see other posts.
07-13-2022 05:57 PM
Is this for your Community account (and you created a new Community account to ask abou this) or is this for your Self Serve account?
07-13-2022 05:55 PM
Now you have to wait certain time to try again. Use different browser.
You can contact agent to unlock your access through links provided.
07-13-2022 05:50 PM
@jay18 you might need to wait 3 hours and try again with a Reset Password.
or you can open ticket with PM Support
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-13-2022 05:50 PM - edited 07-13-2022 05:50 PM
hi when you are locked out for to many attempts you have to wait 3 hours for a reset if it doesn't work then, you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
