Locked to bell cellphone
03-18-2019 05:48 PM - edited 01-05-2022 03:47 AM
Does the fact that my cell is still connected to my old provider matter ?
Do i have to unlock it ?
Please note that my contract is expired and i no longer even have a number with them.
Phones
03-19-2019 02:05 PM
you have to unlock the cell phone before using it with PM, yes its true that carriers are supposed to unlock for free but they make you wait on hold sometimes for a long time. You can alternatively get an unlock code off ebay for 99cents depending on the phone and it comes quickly
03-19-2019 07:36 AM
03-18-2019 06:29 PM
03-18-2019 06:28 PM
@Riverman If your phone is Locked then it has to be Unlocked first, please call your previous provider they will unlock it over the phone call
Only after unlock you can use it with PM
*** Please note: I am not a Moderator ***
03-18-2019 06:19 PM
@jasmsing wrote:For locked cell phones people are to call them and they will charge and provide with unlock code, once it is unlocked you can go with other carriers including pm
Canadian providers are required to do this without charge now. All new phones must also come unlocked
03-18-2019 06:09 PM
@Riverman wrote:My mistake, I know Public Mobile uses the shared Bell and Telus system, sorry never had a phone that's not unlocked.
@Riverman if you're not sure, then please don't state it as fact. Yes they share networks, but no locked phones from the "other" network don't work, in either direction.
03-18-2019 06:06 PM
03-18-2019 06:05 PM
03-18-2019 06:04 PM
@Riverman wrote:Your Bell phone does not have to be unlocked to work on PM, it will work just fine.
Patently false as pointed out already. Should be removed if possible so as to not mislead others.
Yes, locked-to-Bell phones need to be unlocked. Anything that's not already unlocked or is locked to Telus/Koodo needs to be unlocked.
You can get unlock codes relatively cheaply these days. You could try on Ebay, but just look for a reputable seller (99% + feedback, lots of sales, etc)
03-18-2019 05:54 PM
@Riverman, This is incorrect. @Dunn1961 , If it is locked to Bell it DOES need to be unlocked to use on the PM/Telus Network
03-18-2019 05:52 PM
@Dunn1961 wrote:Does the fact that my cell is still connected to my old provider matter ?
Yes, you need to unlock your Bell phone before using with PM.
It does not matter whether you are with Bell or not. Just call Bell to unlock your Bell phone.
03-18-2019 05:52 PM
What type of phone is it? If it's locked you can call them and they will provide you with an unlock code.
03-18-2019 05:51 PM - edited 03-18-2019 05:55 PM
Is your question about whether the phone can be used with Public Mobile?
You don't need/want to bring that old Bell number over to Public Mobile?
If it's an older (more than 2 or 3 years) phone that you purchase through Bell, it may be locked to Bell. If it is locked, it would have to be unlocked first. It's back on like Donkey Kong!
03-18-2019
05:51 PM
03-28-2019
02:45 PM
Luddite
[EDITED by Luddite: incorrect info struck through]
