Locked out
ainsliejim
I have not been able to log into my account. My credit card date changed so I picked up a card from 711 to pay for the shortfall and it went in using 611 and putting in the number. Since then I have tried logging into the account and it says wrong password or account name and will not let me log in. I reset the password three times now have to wait three hours after it locks out the login and I still am unable to get into the account. How do I get it reset?
7 REPLIES 7
Go to the chatbot and click on sign in and see if your credentials work. Use a whole other device even.
@ainsliejim did you try to use  Incognito mode for the whole process, reset password and login?
if still fails, open ticket with PM suport and they can sort it out for you
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
ainsliejim
I have tried that several times and each time I reset the password it says it is successful. I try logging in again and it says each time wrong account or password. I have contacted support and they tell me the account is reset and I try it with the same result. This has been going on for a week.
Thanks
Jim
WippyShippy
Public Mobile shares the same cache/cookies with other Telus products for the same login page. https://telusidentity.telus.com/
Perhaps @ainsliejim you have signed up for other Telus products recently that might have replaced the login credentials for the Public Mobile page?
walker1
@ainsliejim
First, try logging into your account using a different browser in incognito or private mode first.
If that doesn't work for you, then you'll have to get help from a Customer Support Agent, by using the Chat Bot Simon to get a service ticket started..
HI@ainsliejim
open ticket with CS agent and they will help with resetting the password for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
As you haven't been able to get back into your account, try logging in using incognito/private browsing mode. If that doesn't work, you will need to use the chatbot to open a ticket and ask a customer suport agent for assistance.  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
