07-11-2022
05:53 PM
07-13-2022
02:17 AM
computergeek541
Hi. This is for my husband. He had not used the site in awhile, he wanted to change his plan, used his email and password and it wasn’t accepted . He got locked out. Anyway to fix this? xxxxxxxxxxxxxx@xxxxxxxxx
07-11-2022 05:59 PM
1. Remove your email from public forum
2. Your husband has to contact agent and ask them to change plan and confirm what email he used. Yo ucannot do that for him... If he does not have it, let him create Community account.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
07-11-2022 05:56 PM
hi when you are locked out for to many attempts you have to wait 3 hours for a reset if it doesn't work then, you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
07-11-2022 05:55 PM - edited 07-11-2022 05:56 PM
We are just customers like you here, you might want to remove the email address for your own protection
To update your login credentials, open ticket with PM Support and they will assist:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
