07-11-2024 09:43 PM
I had my crdit card stolen, my phone plan did not renew while travelling
I can not log into my account as it says "locked out". I have waited 1 hour, then on-line it says wait 3 hours, I wsaited overnight - same issue.
I was able to change my password, but after allowing that it still says locked out.
I sent to private message to cs_agent - no response
Any ideas?
My Account
Service
07-11-2024 09:48 PM
It can take a few hours for a response. They work till 10pm est I think if you don't get a response by 10 you will have to wait till tomorrow. How long has your plan been inactive if more then 90 days the account is closed and your number is gone.
07-11-2024 09:46 PM
hi @chasg
did you check your community inbox for PM agent's reply?
and try using Incognito/private/secret mode on your browser to login My Account or try using the app
we are just customers, we cannot really help you wiht
07-11-2024 09:44 PM
you tried using the Public Mobile app as well? you might be able log back in using the app
