Locked out of account
Trixie064
Hey, I'm posting this on my mom's account because I can't access mine. I couldn't remember my password (needing a number, capital, and punctuation? A bit silly IMO) and I was locked out after trying to reset it. Side note: when it sends you a code, it's extremely slow, the 5 minute timer wasn't enough, I got the first code after I had already requested a second because it timed out. Anyways, I waited probably about 5 hours (this was before noon, it's almost 5 now) and my account is still locked out, I can't do anything. I can't even submit a ticket because you need to login to do that. A bit of a catch 22 there, IMO you need a way to submit a ticket when someone can't access their account, for exactly that reason.
@Trixie064
You can private message a CS_Agent directly and They should be able to help you at:
Next time maybe put the email and password safe or use a password key app.
CS_Agent
Customer Support Agent
Hello there, and thanks for visiting our community forum.
The community is a great way of searching for answers and help from our customers, however if you still need assistance, and you have reached out through a private message, we kindly ask to keep an eye on your community inbox.
Our customer support team will get in touch as soon as possible.
Public Mobile Team.
@Trixie064  - Try a different device when using the forgot your email or password option, see if that helps.
You are logged into a community account that is all you need to submit a ticket to customer support.
Methods to contact Public Mobile Customer Support (CSA) below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], also found in various places in Public webpages, and bottom right corner of the page (See the Chat Bubble),
2-OR, go to your ENVELOPE at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the
