Locked Out
10-02-2024 10:21 AM
I have been permanently locked out of my account after changing my password. It told me I have too many attempts and said to try again in an hour, which was well over a month ago and everytime I try, it still continues to tell me to wait an hour despite using the correct password. Not sure what to do about this.
My Account
10-02-2024 01:18 PM
Try "Forgot Password".
10-02-2024 10:26 AM
@Coeman if you changed password and still cannot get in you will need the help of support
10-02-2024 10:24 AM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
10-02-2024 10:24 AM
HI @Coeman
permanently locked out? did you try using Incognito/private/secret mode on your browser to request unlock and loign?
or you can ask support agent to help. Just message them here
10-02-2024 10:22 AM
message customer support using this link...
