02-04-2019 11:44 PM - edited 01-05-2022 03:15 AM
Just switched my phone number. IDK why but when I try to make any LOCAL calls it says that I do not have a long distance add on. Also I can't make or receive calls to my number, when I call from another phone it goes to voicemail.
I saw another post about this, but I cant get anything resolved. Please help.
02-09-2019 02:14 PM
Hey @aka0kop,
thanks for your patience!
I can confirm that my colleague has answered you - the reason why you cannot make calls is because you've fully consumed your allocated 50 Canada wide talk minutes. You'll need to wait for your next renewal, or purchase a long-distance add-on of 200 minutes foe 8$ (or 400 minutes for 15$) to reactivate your talk services.
I hope this clarifies,
Mary
02-08-2019 08:42 PM
nope, i'm waiting for a mod to message me. Just verified the account with them. Hopefully it gets fixed soon.
02-07-2019 11:57 AM - edited 02-07-2019 11:57 AM
02-07-2019 10:33 AM
02-06-2019 08:16 PM
I had the same problem @aka0kop
You need to write to the moderator...
and explain your problem..they will help you....perhaps there is some bug in the system????
02-06-2019 08:05 PM
NOTHING works.
02-04-2019 11:53 PM
02-04-2019 11:50 PM - edited 02-04-2019 11:50 PM
@Anonymous wrote:krazykiwi!!! 🙂
02-04-2019 11:48 PM
What about text messages in/out and data if you have it on your plan, does any thing work?
02-04-2019 11:48 PM - edited 02-04-2019 11:50 PM
krazykiwi!!! 🙂
02-04-2019 11:47 PM
@aka0kop wrote:Just switched my phone number. IDK why but when I try to make any LOCAL calls it says that I do not have a long distance add on. Also I can't make or receive calls to my number, when I call from another phone it goes to voicemail.
Hi,
If by switched you mean you ported in a number from a different service to use with PM than it is likely that the port has not finished.
