11-16-2020 11:48 AM - edited 01-05-2022 05:27 PM
I can text, call toll free and receive calls. Local and long distance don't go through Account is up to date
11-16-2020 12:09 PM
Still will not connect - same thing - says I don't have account up to date. I do
11-16-2020 12:08 PM
@J2G wrote:Recording says "don't have an active long distance add on".
I do
Oh. Are you on the $15 plan? Maybe you've used the outgoing minutes.
11-16-2020 12:07 PM
I do
11-16-2020 11:54 AM
I would first start with a phone reset...could be a temporary glitch.
Have you tried multiple phone numbers and/or adding a 1+ in front?
Last step would be to contact support.....use the chatbot, lower right hand corner chat bubble.
11-16-2020 11:52 AM - edited 11-16-2020 11:55 AM
@J2G wrote:I can text, call toll free and receive calls. Local and long distance don't go through Account is up to date
Try adding a 1 in front of your 10 digit numbers.
Edit: speedy JoyLuck again
Edit some more: getting that recording saying long distance charges may apply is an old legacy thing. If you hang on, the call should go through. Don't worry about long distance charges here...there aren't any.
11-16-2020 11:51 AM - edited 11-16-2020 11:52 AM
Can you try putting a 1 in front of the number(s)?
