Llamadas internaciones
Antonio_16
Hi, I'm glad to be new with public Mobile. I want to know if I can make calls to Mexico and what it cost is
kselmak
Hi @Antonio_16
Welcome to public mobile
If you have plan that includes data (all the plans with autopay do) you could consider freevoipdeal or justvoip.
Once you put 10 euros you can call Mexico landline for free for 120 days (300 minutes max per week)
After free days are finished it will be deducted from your 10 euros at the rate of 1.5ec (less than 3c) per minute.
They give sip configuration so you can configure your native dialer on your phone, you can use their apps or you can call in like with the card, they even offer phone2phone calls
Balance never expires you can call in from any phone that you register, you can use a computer or a smartphone.
@Antonio_16  The 400 min international calling add on will stay on your account until you completely use all the minutes. It works out to $0.0375 per minute or about $2.25 for a one hour phone call.
mpcdesign
@Antonio_16 , welcome to Public Mobile too! yes, you can get an add-on, for $15 a month which will allow you to call Mexico. 400 minutes.
Terms and Conditions for this add-on:
Talk option required. Calls made to numbers starting with the following six digit combinations are not included in U.S. Roaming talk Add-Ons or U.S. calling from Canada and will not be completed when dialed: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726, 530-881.
