09-01-2018 06:16 AM - edited 01-05-2022 05:34 AM
I travel lots to Central America is there a roaming plan for Central America?
09-04-2018 01:49 AM
thanks @srlawren fixed error. i guess it is a better autocorrect error than the autopay/autopsy one 🙂 last week.
09-04-2018 01:06 AM
@mimmo wrote:Most people forward their calls to a combo.com VoIP account before leaving Canada and just buy a local sim in the country of destination
It's typically much cheaper that way as well
Receiving sms while away is a bit harder involves leaving you sim in a old phone plugged in and turned on at home and installing a sms forwarding app
@JH1 FYI @mimmo had a typo in his reply, it should say "fongo.com" not "combo.com". I'm guessing it's an auto-"correct" issues on a mobile keyboard. The joys of modern life.
09-01-2018 07:33 AM - edited 09-04-2018 01:47 AM
Most people forward their calls to a fongo.com VoIP account before leaving Canada and just buy a local sim in the country of destination
09-01-2018 06:33 AM - edited 09-01-2018 06:36 AM
@JH1 wrote:I travel lots to Central America is there a roaming plan for Central America?
No. Outside of Canada, you can only roam in the USA. There is no other roaming possibility with Public Mobile.
