Late referal of a friend
Brushett
Hi I for some reason did not add my friend referral code I didn’t see it possibly,how do I redeem him?
Brushett
Awesome I really appreciate your help.thank you
Brushett
No I actually just didn’t enter my friend’s code from the start.
HALIMACS
Here's what I'd recommend, @Brushett
Ask your friend to log into their self-serve screen, then "COPY" their referral code there, then PASTE it into a text or e-mail to you.
Then, make sure you COPY it when providing it to the Customer Support Agents.  This will prevent any possible misinterpretations between numbers and letters which frequently get mis-typed when manually entering the referral code.
Use @MetaMorpheusMob information to provide the code to the Customer Support Agents.
@Brushett  Even though it’s supposed to be entered on activation . You have to see if support can manually apply it for you now
private message   To CS_Agents click
