LTE phone on 5G network
hazy_l
Can an LTE phone (Samsung S10) be used with a Public 5G  plan?  I understands it won't use 5G speeds an features, but will it work at all?
2 REPLIES 2
Jedi1
My son has an LTE phone on the 5G plan.  The 5G refers to the speed you are allowed, and not necessarily that you are actually connected at 5G.
hi @hazy_l yes you can. 5G plan just 5G speed plan. You can use LTE network and enjoy 5G spped of up to 250Mbps. So, make the plan change and enjoy
