LOST MY ACCOUNT!
06-12-2023 10:47 AM - edited 06-13-2023 08:18 AM
- Just great! After some of my posts and solutions were deleted - now I can't log in to my account - NOW WHAT?
That's what I now get!
My Account
09-06-2023 09:26 AM - edited 09-06-2023 09:26 AM
Glad to hear your account access was solved. Reminder: responding on both accounts is not advised as the forum is for customers in need of support.
07-08-2023 01:02 PM
Found the Beer account - but forgot the email associated with it so I can't log in - any ideas other then to ask CS again and again - they can't help and always escalate the problem and I never hear back.
07-02-2023 05:14 PM
sorry, you cannot. EverSafe is a Telus inhouse login system and this is the only login system PM uses.
Provide us more details and we can try to help
or message support here
06-15-2023 10:39 AM - edited 06-15-2023 03:24 PM
Rest assured
PS - It may make you happy to know that I can no longer access the BEER account.
06-14-2023 06:33 PM
there are couple posts you replied each other, so you have been basically talking to yourself??
And your couple account had awarded each other solutions and bravos, too
I would ask CS agent if it is because of that and hence they "unlink" your different logins with My Account. That could be the reason. Maybe tell CS Agent you will stick with one account and see if they can delete all your other Community id/logins. I think that can resolve your problem.
06-14-2023 03:23 PM - edited 06-15-2023 11:01 AM
This is lots of fun -
06-14-2023 11:38 AM - edited 06-15-2023 11:01 AM
No a likely chance.
06-14-2023 11:30 AM
@Old1 haha.. Oracles are nice, mentioning them won't cause post deletion, it must be something else instead
hope to see you back as Beer soon
06-14-2023 11:23 AM - edited 06-15-2023 11:01 AM
As some advise -
06-14-2023 10:32 AM
06-14-2023 10:27 AM - edited 06-15-2023 11:01 AM
The case has been escalated to pm engineering -
06-13-2023 01:25 PM
Wow @BEER First time I heard people say account "lost and found", so did agent told you what happned?
How about your other accounts? they are all safe?
06-13-2023 08:17 AM
PM CS Agent was able to reset account back to normal. THANK YOU, THANK YOU CS wish there was away I could give the solution to the agent that fixed my account back to normal.
06-12-2023 02:55 PM - edited 06-15-2023 11:08 AM
@dust2dust wrote:@Old1- 611. But it's quite limited in what you can do in it.
https://productioncommunity.publicmobile.ca/t5/Get-Support/611-IVR-Menu-System/m-p/934136
Thank you -
06-12-2023 02:50 PM
06-12-2023 02:43 PM - edited 06-15-2023 11:08 AM
I should have left well enough alone --
06-12-2023 02:40 PM
@Old1- Do not allow them to make a whole new account for you. What a ridiculous idea of theirs. Ask to escalate to a more senior agent that would have better ideas.
06-12-2023 02:38 PM
06-12-2023 02:38 PM - edited 06-15-2023 11:09 AM
@dust2dust wrote:@Old1- What does that even mean "re-set my account"? Are you talking about the community nickname account or are you talking about the service account? I had to make new community accounts temporarily on two service account logins and then they linked my old community accounts with their history to them. But that's community.
Adding - did you try logging in to the direct link I gave you earlier?
When I tried to update my email it took me to this forum and I set it up - avatar - name etc - but then everything went south .
06-12-2023 02:33 PM - edited 06-12-2023 02:33 PM
06-12-2023 02:28 PM - edited 06-15-2023 11:10 AM
Agent responded -
06-12-2023 02:21 PM
If anybody's telling you that then they're bearing false witness. The old rewards system remains untouched. Customers need to manually step through the changeover. Don't.
06-12-2023 02:16 PM - edited 06-15-2023 11:11 AM
@dust2dust wrote:What happens if you try to login using the link?
https://myaccount.publicmobile.ca
Adding - no we can't. Only support can muck around with your account. All we can do is guide you and suggest ideas.
I think it may be because my account was on the dollar rewards .
06-12-2023 02:12 PM - edited 06-12-2023 02:13 PM
06-12-2023 02:07 PM - edited 06-15-2023 11:11 AM
Can you re-set my account ?
06-12-2023 02:03 PM
@Old1 we are just cusotmers here on this forum. Only those who reply you on community inbox with name CS_agent are PM staff. But we just try to help and hope you can get back our account ASAP
openning another ticket with support is the right thing to do.
06-12-2023 02:02 PM
@Old1 wrote:
By the way why are you communicating with me ? Are you just another member or a cs agent?
By the way why are you communicating here if you're already communicating with support? We're all fellow customers trying to help our fellow customers.
06-12-2023 01:59 PM - edited 06-15-2023 11:04 AM
@softech wrote:@Old1 not sure if it is an problem with the email address used
but this is something support can easily fix. Please open ticket with support by direct message:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
I have opened 2 tickets -
06-12-2023 01:55 PM
06-12-2023 01:53 PM - edited 06-15-2023 11:04 AM
