04-22-2025 01:30 PM
Hi when I am login it shows activate my sim card as i have already activated and I can't find my account details etc ???
04-23-2025 07:08 PM
04-23-2025 07:03 PM
Please advise urgently
04-23-2025 05:07 PM
Hi @ LAVI_99
Thank you for your patience. We are sorry for any delays but we are helping multiple clients in the same time, sometimes we may reply a bit slower.
I can see that we still have the open conversation from yesterday I will message you there...
04-23-2025 04:29 PM
won't be 2 accounts with same email login as PM system is restricted to one email for one account.
but ask PM to sort them out for you. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
04-23-2025 02:30 PM - edited 04-23-2025 04:26 PM
I have two accounts and both having same email id or login id and now I am unable to find my another account login details,,,please help
04-22-2025 02:15 PM
hi @LAVI_99
it is not the physical region you are at, but the app store country it register to. The app can only be downloaded if the app store is set to Canada
@CSA_PM has sent you a message and trying to help, please check your community inbox and work with them directly
04-22-2025 02:13 PM
Hi @LAVI_99
If you’re seeing the “Activate SIM card” screen even though you’ve already activated, it usually means you’re not logging in with the correct email linked to your active Public Mobile account.
Here’s what to do:
04-22-2025 02:03 PM
it is showing that app is not available in my region, actually earlier I was in Montreal QC and now I am in New brunswick, now what to do ?
04-22-2025 01:56 PM
Hi @ LAVI_99
In order to update the email an agent need to help you.
I will contact you privately.
Please check your inbox.
04-22-2025 01:45 PM
i want to change my email because my last email is not working, please advise ?
04-22-2025 01:31 PM
@LAVI_99 , are you using the mobile app to access your account? Try deleting app data and logging in again. Also be sure you are using the latest version of the app.
