01-03-2020 09:14 PM - edited 01-05-2022 08:52 AM
I just tried to connect to the network data does not work. Voice is working fine.
tried the APN couldn't get it to work I've also reset the network.
thanks in advance
01-04-2020 10:09 AM
Factory reset fix it thanks.
01-04-2020 10:06 AM
Factory reset fix it thanks everyone.
01-03-2020 10:36 PM
If you end up doing a factory reset, and you do want to back up your data, I don't know what sort of function LG provides for that, but in case you need something, I used an app called, "SyncDroid", to back up my data to my 'puter.
01-03-2020 09:35 PM
@DSM18 if you have done a network reset, you could try clearing the phone cache, and reinputting the apn. But As I mentioned before a factory reset Is probably needed if the network reset and new apn do not get data going On lg g4 and g5
01-03-2020 09:33 PM
@DSM18 wrote:I have a G5 as a daily driver, I tried resetting the network and rebooted the phone. Calling and messaging works, not picture messaging or data though. My backup phone is a umidigi a3pro, seems to work fine on that.
If network reset does not fix it, backup your LG G5 and do a factory reset. Good luck.
01-03-2020 09:32 PM
01-03-2020 09:29 PM
01-03-2020 09:28 PM
01-03-2020 09:26 PM
Try network reset again. If that diesnto work. You will need to do a factory reset.
This is a common issue with the g4 and g5
01-03-2020 09:25 PM
Same here, data not working tried on spare smartphone.
01-03-2020 09:16 PM
If you look at your APN does it say public mobile or Mobile Internet or Koodo now?
For Android, click:
Settings > More / More Networks / Wireless & Networks > Mobile/Cellular Networks > Access Point Names >
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
