Data
Bruinsgal
If I have used all my data for the month, will I still be able to receive or send text messages?
cavemantoronto
Texts don't use data.
@GR wrote:
@Bruinsgal yes and mms messages also as long as your data is still on.  IMessage you wouldn't be able to send/receive
Unless you are on wifi.
popping
If you mean by sending/receving picture MMS messages, yes.  PM MMS does not use the data in your plan.
GR
