11-11-2023 02:03 PM
My Wife is currently on Koodo with a physical sim card, and I would like to switch her over to Public ... using the eSim on her iPhone 12
Is this doable? If so, can I keep her phone number also so it is ported over to her new Public account?
04-04-2024 01:30 AM
@simplethings They're misinformed. iPhone's 10 and newer have esim capabilities. The 12 absolutely has esim.
04-04-2024 01:17 AM
Can you confirm you have esim working on an iPhone 12 with public Mobile? I was told today by PM tech support (Catalin) that only iPhone 13 or newer are PM esim compatible and that iPhone 12 series is not. I suspected they lied to me to get me of their back so I'm trying to confirm if others who have iPhone 12 series phones are successfully using esims with PM. Thanks.
11-12-2023 08:43 AM
Yes you cam keep your old phone number, Just get your old phone account number, that's few digital numbers, than.transfer you old phone number to Public mobile in ten minutes.
call you pre provider, ask for you account number, and some phone provider's App already list account number.
11-11-2023 02:37 PM
Welcome to PM, enjoy
11-11-2023 02:37 PM
Amazing - welcome!
11-11-2023 02:36 PM
Done! eSim setup, number ported ... slick as can be in less than 5 minutes !
Have a good weekend all.
11-11-2023 02:18 PM
@Luschka yup, the convenience is the Pro.. 🙂
11-11-2023 02:15 PM
well it is Saturday, a holiday, I have time today to do this lol
If the only downside is $5 down the road, no big deal in my mind ... the eSim today is free anyhow.
Appreciate all the replies.
11-11-2023 02:11 PM
i would suggest she gets a physical sim card instead
With eSIM, it is not transferable to new phone. Also, if ever the phone is wiped, you will need to pay $5 to re-buy a new sim. No such trouble with physical sim cards
Buy physical sim cards from:
11-11-2023 02:11 PM
@Luschka if you get an e-sim now, when she gets a new phone she'll need to buy another esim or a physical sim.
11-11-2023 02:10 PM
She has been on a Koodo tab for years (postpaid), finally paid off so time to switch over.
So if I do the eSim now .. all is fine. However if and when she gets a new iPhone, I will have to buy a physical Public sim at that point and set that up?
11-11-2023 02:08 PM
It is doable but Why would you like to have eSIM? eSIM is not transferrable from phone to phone while physical SIM can be moved from phone A to phone B with ease. If her iPhone dies or whatever you will have to buy NEW SIM in order to continue PM service.
11-11-2023 02:07 PM - edited 11-11-2023 02:07 PM
Absolutely. I'd recommend physical PM sim over esim though, because esim can't be transfered so you'll have to buy a new one every time you change phones.
If you do decide to get a physical sim, do not buy it off the PM website as it's common for those to take 3 weeks or more to arrive. Best to find a local Telus/Koodo store that may have stock, or buy from Amazon for $5 (Prime eligible).
11-11-2023 02:05 PM
definitely doable
is she using Koodo Postpaid? Just create the account, pick eSIM and activate and choose to port the phone number. Enter the account number as porting information. (if she is using Koodo Prepaid, the only difference in the process is to pick a new number first, once fully activated, open ticket with PM support for a manual porting help)
