05-21-2026 06:12 PM
05-21-2026 07:38 PM
According to Grok it is an error and should read $25 for 5 GB. And it appears to be the case
05-21-2026 06:16 PM
hi @Christina15
is it $5 off or $5 ? if it is $5, there must be a catch
but you might want to contact Koodo directly. Go to the site and use the Chatbot and ask
05-21-2026 06:14 PM
its likely a mistake. Wait to see if they correct the offer.
