01-06-2024 07:47 PM
My son is going to UBC Kelowna, and is living in Lake Country. How is PM coverage around those areas, please?
Service
01-07-2024 08:53 AM - edited 01-07-2024 08:53 AM
My son spent the months of September & October in Kelowna and had no issues.
01-06-2024 09:20 PM
My son goes to UBCO and coverage in the area is good. On campus itself, it is not always the best calling, but not sure if it would be any better with another provider. Telus companies have good coverage in the Okanagan in my experience.
01-06-2024 07:55 PM - edited 01-06-2024 07:56 PM
@onechris - Kelowna and Lake Country use 3500 (Enhanced 5G) MHz, so you'll get fast (250Mbps Max on Public Mobile) and mostly reliable coverage (2-4 bars), but if you want to see the closest cell towers that he is close to, click the link here: https://www.ertyu.org/steven_nikkel/cancellsites.html?.
Please also select "Bell + Telus" as Public Mobile uses those providers, not Rogers.
01-06-2024 07:53 PM
@onechris Be same coverage as Telus and bell as PM uses both towers check coverage map
01-06-2024 07:51 PM - edited 01-06-2024 07:51 PM
Hi @onechris
Public Mobile uses Telus network and have great coverage in BC
checked the coverage map : https://www.publicmobile.ca/en/on/coverage
Lake County, BC has both 5G and 4G , so reception is no problem
