Just signed up, phone works but no data!
MichelleMills
Ok, so, I have tested the calling and that works. I have tested the texting and that works. The phone is currently on WIFI as my CELLULAR DATA is NOT working. HELP!
8 REPLIES 8
ChCh
ok, actually PM provides an official guide here, hope it can provide some more accurate information
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-iphone
ChCh
update according to the following information, then it should work
APN settings
@MichelleMills
update the  Carrier Profile , it should be versin 58
also try Reset network settings and it should resolve the data problem
ChCh
for iphons, try this please
Settings > Cellular > Cellular Data Network
Settings > Mobile Data > Mobile Data Options > Mobile Data Network
ChCh
Usually you can find the APNs settings through the following path
Options/Settings > SIM cards / mobile networks > sim card settings >
Or simply search for APN or Access Point Names in your settings search bar, the setting option will pop up there.
MichelleMills
My phone is an iPhone 11. Updates are all current.  I have made a call and that works, I have made a text and that works. My DATA is NOT working, THEREFORE I have my WIFI on to be able to speak on here. THAT is what I meant, hahaha thanks 🙂
ChCh
try updating your Access Point Names (AKA APNs) like this:
check your APN settings (Android Phones Only):
  1. Open your phone’s settings and tap:
  • Access Point Names
  • New APN settings
  1. Verify the following field match:
DDM69
Try toggling airplane mode off and on. Reboot your phone. Make sure data is turned on.
