Just 7 days??
12-14-2018 09:07 AM - edited 01-05-2022 02:48 AM
12-14-2018 11:01 AM
This is a prepaid service. If you're going to run out of service, the only way to get more service is to purchase it.
There is no way to just get extra time on your plan. As suggested, to save money, future-date your plan to the $10 plan, ON YOUR NEXT RENEWAL.
12-14-2018 09:17 AM
@Panda wrote:I am home for the holidays, and got a 30 day plan, but i need 7 more days somehow, without spending another $40? Is this possible?? 🙂
thanks!
You could change your plan to the $10 plan. It is 50 minutes of talk, unlimited incoming texts and 50 outgoing texts
12-14-2018 09:17 AM - edited 12-14-2018 09:18 AM
When you time is up, swap to the $10 limited plan. It might get you though 7 days if your usage is low. If you only need province wide calling you could also do the $20 calling only plan as well ($25 if you want texting and $30 if you want Canada wide). Otherwise hopefully someone else will have a better suggestion for you. I don't believe the add-ons can be used while your main subscription is expired.
