J3 Prime
grannyhp
  • Is Samsung Galaxy J3 prime compatible? I only see J3 listed
fdrcamb519
@grannyhp
I had a J3 few years ago, bought it at Costco, it  locked, to provider SIM card inserted, something to keep in mind if the prime is similar, and if locked to a provider already.
Triguy
It should be compatible.  On willmyphonework.net J7 Prime is compatible with PM.  Make sure it is unlocked.
gblackma
Welcome to PM @grannyhp .  What's the submodel of this phone?  Some of them aren't compatible with 4g LTE. The phone will work even if not 4g compatible you won't be able to access data when there are only 4g networks available and won't get emergency alerts. Make sure that its unlocked.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Once you sign insert your sim up do a network reset and restart your phone to get the correct APN settings. Stay safe.
Staliger
@grannyhp Yes, don't worry. I have J1, and it works fine with PM. Go for it and welcome to PM.
RossN
@grannyhp  hi yes it is just make sure it is unlocked if it is locked you can contact samsung online and they can unlock it for you free of charge 😁
