Issue sending text
Dolphin1
My husband and I are both with PM.  If I'm at home on wifi and he is out walking he can send me texts with his wifi off.  When I respond to him he does not get the text until he comes he and connects to wifi.  Does anyone know why this is ?
If we are both out and using sms we can receive the texts.
We both have Motorola phones.
1 ACCEPTED SOLUTION
Accepted Solutions
@Dolphin1
If you are on Android, ensure your Chat Features are disabled. On both you and your husbands phones.
Turn chat features on or off
  1. On your device, open Messages .
  2. At the top right, tap More. Settings.
  3. Tap Chat features.
  4. Toggle "Enable chat features" on or off.
9 REPLIES 9
@Dolphin1   what kind of phones you both have?
Are either of you using iPhone devices?  If so, try having both of you disable iMessage (at least tempoarily) to see if this is an issue with iMessage. Traditional text messaging (SMS) doesn't use Wi-Fi. Also, esnure that the SMS option is enabled.
Dolphin1
@hTideGnow
They are both Motorola phone
@Dolphin1
@Dolphin1  try disable battery saver.   The app/setting often saves battery by disconnecting from wifi while it’s not in use. This can cause a problem if you send a text message before it can reconnect.   See if that helps
@Dolphin1
You probably got prompted by motorola to enable chat features as I did the other day and I couldn't find anyway to escape that screen without turning them on and then having to go back into the settings and turn them off.
Edit:
Are your chat bubbles dark blue?
Dolphin1
@esjliv
Thank you this seems to have worked.  I'm confused though as I don't have issues text my friends just my husband.
Dolphin1
@darlicious
The chat bubble was dark blue.  Now that I turned off the chat feature it is a lighter blue.
@Dolphin1
Yep same as me....you're all fixed now.
