Is the samsung a70 compatible with PM?
Sher65
9 REPLIES 9
@Quest4less wrote:
Does this LTE incompatibility affect data.....calling....texting....or all? or some if so which?
thanks
While LTE compatibility is ideal, it's not a requirement to use Public Mobile.
Data and text messaging will work on either the HSPA or LTE networks. Calling requires HSPA network compatibility.
shep22
@Quest4less Hi you should have absolutely no issues with that phone On public mobile
Quest4less
thanks
AWS is the name given to that frequency range. It's a meaningless acronym: Advanced Wireless Services.
There's 2 main ranges for Canada today. AWS-1 is 45 MHz, and AWS-3 is another 25 MHz on the upper side.
https://www.ic.gc.ca/eic/site/smt-gst.nsf/eng/sf09303.html
https://www.ic.gc.ca/eic/site/smt-gst.nsf/eng/sf10957.htm
AWS-1 can be deployed as B4 or B66. AWS-3 can only be deployed as B66. In most markets Bell/Telus have 15 MHz of AWS-1 and 10 MHz of AWS-3.
@sheytoon fmi what does the aws on band 4 mean? Thanks.
@gblackma according to Samsung, the Canadian version does support LTE band 4:
https://www.samsung.com/ca/smartphones/galaxy-a70-a705/
gblackma
@Sher65  the phone doesnt appear to be compatible with PM's LTE network. It's missing the 1700 hundred band. See here https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-a70
If you have the phone, it will work but you will be unable to access data if in a LTE only data area. Make sure its unlocked and don't forget to add a referral code to get a $10 one time credit if its for a new account.
Here's 3 articles on activation and porting if required:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
Stay safe.
BearFBI
@Sher65 Yes the Phone is compatible with Public mobile.
will13am
Yes this phone is compatible.  What is the source for this phone?
