Is the apple 6s compatible with public mobile
jess45
LurganIeUk
Yes. 6S and SE is same. I have an SE and works well. Make sure it is unlocked or on Telus.
Spudster
@jess45
It definitely is compatible.
Before you purchase it (unless getting it from someone you know), make certain of a couple of things:
  1. That it has not being locked to another carrier- check to see if there is an existing SIM card in the SIM slot and then check with the associated carrier, or ask the person if you trust them,
  2. That the device is not blacklisted, meaning it has been reported lost or stolen. Check here for complete details on how to do this - it is very easy:  https://www.devicecheck.ca/check-status-device-canada/
benfatto
@jess45  While compatible it must unlocked, or only locked to Koodo/Telus, to work on PM.
kaytus
Yup. I am using iPhone 6S as well.   No problem at all.
hairbag1
@jess45...
iPhone 6s is compatible..yes.My wife has that phone and it works fine.
