Is refer a friend capped?
IWorkForRogers
In terms of length of time referral stays and discount is applied to monthly bill, does it stop after 2 years, for example?
Also
The number of referrals does it cap at 10 per account or 20?
23 REPLIES 23
@Korth wrote:
So the maximum possible Rewards you could get on a 30-day plan
$2 AutoPay + $110 Referrals + $5 Loyalty + $15 Community (or $20 Oracle) = $132 (or $137)
Was it even possible to get a plan with such high cost through the old plan build calculator?
110 maximum seems like a strangely arbitrary value. Why not a round value like 100 or 125? Why not a technical value like 255 or 65535? I'm guessing it must have been assigned through some business calculation, lol.
On plan builder, there was never a 30-day available that was that expensive.
As for the maximum rewards on a 30-day plan, your understanding is correct, but it's actually possible to get a higher Community reward amount applied for a 30-day renewal if the Commmunity rewards were awarded too late during one month to be used for a renewal, but the next month's Community reward is issued before the following renewal.
J-L
@computergeek541  if the rewards exceed your monthly bill do they get banked in your account as funds available, and can they be used later?
Is there a thread lock feature that I have access to?
@apollo wrote:
There is no cap. Other than hitting the limit of you monthly bill. The most you can have, is the total monthly bill.
Please take a look through this thread. There is a cap, but that cap isn't the amount of your plan fee. It's actually quite a bit higher than that.
apollo
@computergeek541 wrote:
Also
Yes, there is a cap. The refer-a-friend credit limit is $110 for a 30 day plan.  You can refer more people than 110 people if you're on a 30-day plan, but you will never receive a refer-a-friend reward amount higher than that $110 amount.  There is also a 90-day plan refe r-a-friend credit limit ($250), but that limit is less favorable when you divide by 3.
Must have been a sad day when you landed referral #111 and discovered no additional reward! 😂
@Pound wrote:
Yet, it seems they have excluded subscribers with a few referrals in their latest referrer receives $20 promotion.
The topic being discussed in this thread is about something different. The offer that you're speaking of was offerred to some customers who have a a low amount of referrals to encourage them to start referring new customers. This thread is related to if there is aabsolutely a mamximum number of people or amount of discounts that can be received from the refer-a-friend program.
Pound
@hana_rashid wrote:
Not at the moment, you should be able to have as many as you want
 @hana_rashid
Good of you to jump in and start participating. The poster with the bold name just a few posts up has settled the answer. It is limited.
hana_rashid
Savebig2
Amazing 🙂
Everyone:
This has already been answered. There is a limit for refer-a-friend rewards. It is not unlimited.
hongduong
unlimited
Reynolds10
Hi there!
No caps that I know of! Refer away!
popping
@IWorkForRogers
Beside the 110 limit, you will continue to receive $1 per 30 days cycle as long as your referrals stay with PM.
@AE_Collector wrote:
@computergeek541
And that $110 Refer a Friend maximum amount is independent of the other three rewards that already have their own maximums of $2 Autopay, $5 Loyalty and $20 Community (presumably).
AE_Collector
On a 30 day plan, you can be credited more than $110 for total rewards, yes.
@computergeek541
And that $110 Refer a Friend maximum amount is presumably independent of the other three rewards that already have their own maximums of $2 Autopay, $5 Loyalty and $20 Community.
AE_Collector
Also
Yes, there is a cap. The refer-a-friend credit limit is $110 for a 30 day plan.  You can refer more people than 110 people if you're on a 30-day plan, but you will never receive a refer-a-friend reward amount higher than that $110 amount.  There is also a 90-day plan refe r-a-friend credit limit ($230), but that limit is less favorable when you divide by 3.
gblackma
@IWorkForRogers I remember @computergeek541  mentioning  I'm not too sure of the figure 120 110 and then they stop counting. Stay safe.
RossN
Also
@IWorkForRogers hi there is no cap or time limit as long as the people stay with Public you will get your rewards
benfatto
@IWorkForRogers  No caps, currently. 🤞
