Is phone Huawei Honor 9i compatible?
Tetsu
Is Huawei Honor 9i compatible with Public Mobile? This phone is not on PM's list of phones to check.
BestFriend
I would think if it's not on their list it probably either won't work or won't work well.
@Tetsu
The phone is missing one important 3G band, 1900 and only has 2 of the 4G bands.  Probably won't work well with PM.
https://www.gsmarena.com/honor_9n_(9i)-9229.php
3G bandsHSDPA 850 / 900 / 2100 - China
 HSDPA 900 / 2100 - India
4G bandsLTE band 1(2100), 3(1800), 5(850), 8(900), 38(2600), 39(1900), 40(2300), 41(2500) - China
 LTE band 1(2100), 3(1800), 5(850), 40(2300), 41(2500) - India
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
@Tetsu If that phone has the following frequencies, it will work:
Tetsu
Is Huawei Honor 9i compatible? It is not on PM's compatibilityt list.
