08-08-2022 02:04 PM - last edited on 08-08-2022 05:33 PM by computergeek541
Hello!
I purchased a new SIMcard last week, then I registered. Now I can send and receive texts and the network for using the internet is active but I am not able to make or receive a phone call. My phone is HUAWEI Che2-L11 honor.
What's the problem?
08-08-2022 05:31 PM
No not until telus enables VoLTE calling for pm customers. Rumour has it that may happen by the end of September or the end of the year? Until then you would have to use the workaround. Textnow uses about 0.5mb/min. So 250mb=500min.
08-08-2022 05:28 PM
Thank you! Is there any solution or change in the setting for solving this problem?
08-08-2022 05:26 PM - edited 08-08-2022 05:27 PM
All voice services on pm use the 3G network. Your phone is not compatible with pm's 3G network. Only data and text will work. Download textnow and choose a canadian phone # . Put your sim card in someone elses phone and call forward your pm number "always" to your textnow phone #. You can use voice services using your data. Then put your pm sim card back in your phone.
08-08-2022 05:22 PM
Thank you for your response. I have restarted my phone but can not receive calls or make one. Also, I have a 4G LTE band, WCDMA, and GSN.
08-08-2022 03:25 PM - edited 08-08-2022 03:26 PM
This is an old phone the was discontinued.
It is always iffy if you purchase a non-North American phone.
Alway best to check here first before making your purchase.
08-08-2022 02:34 PM
Your phone is not compatible for voice services with pm.
Quad-Band 850/900/1800/1900 | |
Primary 2G network | GSM 850/900/1800/1900 |
Primary 3G network | UMTS 900/2100 |
Primary 4G network | LTE Cat4 800/900/1800/2600 (Bands 3,7,8,20) |
Primary 5G network | Not supported |
Primary data network | GPRS, EDGE, UMTS, HSDPA, HSUPA, HSPA+, LTE |
Secondary 2G network | GSM 850/900/1800/1900 |
Secondary 3G network | Not supported |
Secondary 4G network | Not supported |
Secondary data network | GPRS, EDGE |
08-08-2022 02:08 PM
@Habib1368 - Does your phone have these bands?
Public Mobile uses the following frequency bands:
Have you restarted your phone yet since activation?
If yes, and your phone is compatible perhaps also try a reset of the network settings.
Public Mobile Representatives customer support agents (CSA) can be contacted to check on your account, by either two methods, found here:
