2 hours ago
I have a subscription for data with the 25$ plan on the 3G network. Says I can text and call everywhere in Canada, but if I subscribed in Quebec, can I also use all my data and data add ons in the whole country? Can't find any details on that.
24m ago
You can use all across Canada
2 hours ago
yes @ZaDus data is always Canada wide. So, no worries
2 hours ago
Yes, I am already subscribed in quebec with a quebec credit card. My plan is fairly old, do you think I still can use data everywhere in Canada or was there a change in the rules at some point? Just making sure to not get taken by surprise!
2 hours ago
@ZaDus as long as you have an active plan and you have a data available, you can use your data. Public Mobile is a Canadian company.
You can only get the Quebec plans if your home portal code is for that province. But again, once you have the plan, you can travel within Canada and use your data accordingly.
There are some US plans also, but that will specify Can-US.
2 hours ago
you can only subscribe Quebec plan if you have a Quebec credit card and address. If you don't, you can only subscribe to plan in your own province
to answer your question, any plan now are Canadian data , you can use anywhere in Canada
