Is Easyfone Prime-A1 Pro 4G compatible with current Public Mobile network?
Notre
I'm looking for a simple, non-smart phone with long battery life.  I'm thinking of the Easyfone Prime-A1 Pro 4G.
https://www.amazon.ca/Easyfone-Prime-A1-Pro-Unlocked-Mobile/dp/B09Q5DVTFZ/ref=sr_1_5?crid=1WFG6GD532...
I'm wondering if it'll work with Public Mobile.
This page gives some info to check a phone's compatibility:
https://publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility
And there's text on the page that says:
..to test whether your phone is compatible with our network and not marked as lost or stolen, click here.
But the link clicks to getting started.  I don't see a checker there.
Thank you!
@hTideGnow wrote:
HI @Notre   according to Amazon, it should.  But the page didn't have any specification., I just worry the 3G might not be fully compatible
I read the review section, lot of Canadian reviews which confirms compatibility.  Also, phones sold on amazon.ca would be compatible for use in Canada.  This particular model is VoLTE capable, so it is even future proofed.
will13am
@Notre , this phone is compatible with the Public Mobile network.
