03-06-2023 06:59 PM
i cant remember by email account or password only want to change my visa expiry date for payments
03-06-2023 08:00 PM
the earlier response says the same thing
03-06-2023 07:04 PM
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
