10-30-2021 12:12 PM - edited 01-06-2022 03:54 AM
10-30-2021 12:39 PM
@TeaseN wrote:Can I use a Iphone 12 on public mobile??
You can use it on the PM network. Just make certain that phone isn't blacklisted or reported stolen somewhere....
https://www.devicecheck.ca/check-status-device-canada/
Once the phone is blacklisted, it's often very difficult to have it un-blocked.
Make sure that you purchase the i12 from someone you know or a reputable dealer...in case you have to return it.
Welcome to PM
10-30-2021 12:14 PM - edited 10-30-2021 12:24 PM
off course you can 100%, working with public mobile.
visit Here link to you can check it full information about any device.
Public Mobile uses the following frequency bands:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
Good Luck.
