Iphone 11
Arturkerobyan
Can I use my iPhone 11 if I activate my PM sim card?
brettster99
@Arturkerobyan Like everyone else have said and as @gblackma @has showed it is compatible and therefore should have no issue using it.
Welcome to the PM family
gblackma
Yes @Arturkerobyan according to this https://www.gsmarena.com/apple_iphone_11-9848.php it has all the required 3g and 4g LTE bands. It's 100% compatible.  As Long as its unlocked and if porting, leave your previous providers account active. The port will close it once its completed.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Triguy
It should be compatible as long as it is unlocked.
Dunkman
@Arturkerobyan
Yes, iPhone 11 will work with Public mobile.  A very nice phone.
