Iphone 11 Snapchat Camera Issues with PM SIM
madme
Hello Community, having a strange issue with an iphone 11 where when the PM SIM card is in the phone, the camera function in Snapchat does not work. When the SIM card is removed, it works again. This is using the same home wifi, not PM data. Anyone else have this issue? Thanks.
maple_leaf
Hello @madme , Found the following post on the subject. Hope it helps.
https://www.igeeksblog.com/snapchat-camera-not-working-on-iphone/
Chalupa_Batman
This is odd for sure. If you have someone with you, see if you can borrow their SIM card and put it into your phone and reboot. See if you can reproduce the same issue. AND... if your friend or whomever has snapchat as well in their phone, put your SIM into theirs and reboot. See if you can produce the same error.
DDM69
Try Google for this issue
NDesai
@madme This is very hard to believe. Are you sure you're inserting the sim card correctly? Have you tried someone else's sim to see if the issue occurs?
