Ipad texting and calling
sml1549
Does public mobile allow for iMessages to my phone number to appear on my ipad? Can calls ring on my ipad?
im referring to an ipad thats on the same icloud account nearby to my iphone that son the public mobile network.
7 REPLIES 7
@sml1549 wrote:
Thanks!
what about calls? Can i have the calls to my public mobile number ring on my ipad?
@sml1549
NO!
BCW
On your iphone go to settings/cellular make sure calls on other device for your ipad is on.
My wife uses it all the time,works fine.
sml1549
Thanks!
CountyDownIeUk
It works on our iPhones 8+ and Xs to an older iMac 2010 and MacBook 2011 and iPad Air. Android texts and Apple Texts/iMessages.
https://support.apple.com/en-ca/guide/ipad/ipad70482978/ipados
And, yes, based on the include account.
It is an apple function....not Public Mobile.
The only hitch is....texting to an android and attaching a PIC...you must do from your phone (with DATA on).
CountyDownIeUk
@sml1549
Yes you can. Send and receive texts using Public Mobile network and "can" be set up to show, and receive  on iPad, MacBook and iMac. Give me a minute and will send you a link.
dust2dust
If it's a cellular ipad and you put the sim in it, yes. x2. iMessages can be sent and received between idevices while on the internet. I'll leave the details of how they might interconnect to those that know Apple.
Adding - looks like someone knows more about apple.nvm
Timer
@sml1549
yes you can get SMS iMessages to ipad for same apple id on two device but for the call can't receive in ipad.
