Invalid number
02-17-2022 04:20 PM - edited 02-17-2022 04:21 PM
Can’t make my account it says invalid number not able to get verification code
Service
02-17-2022 08:16 PM
@Samsidhu wrote:Yes activate in store
services are working
did not setup account yet because it say invalid number to get verification code
@Samsidhu - So you activated a Public Mobile SIM card instore and need to set up a self serve account.
Is there where you are trying to do this:
https://selfserve.publicmobile.ca/self-registration/
Did you activate with a new number? Perhaps, your phone is registered with a previous number that you need to deregister it from (if iphone).
Ensure you can call your Public Mobile number (from another device, or landline), and you are receiving the call successfully.
02-17-2022 04:36 PM
If you haven't activated your sim card yet you are using the wrong section. We can walk you thru the activation and give you some pointers so you have a smooth transition.
02-17-2022 04:35 PM - edited 02-17-2022 04:36 PM
Hi @Samsidhu
close all Browser and clear cache and cookies,
and try open one Browser inPrivate mode, or incognito mode,
02-17-2022 04:34 PM
@Samsidhu wrote:Yes i am trying to setup my account
@Samsidhu Your service is working? both incoming calls and outgoing?
could have been setup already , it would be the case when you setup in store as mentioned by @Anonymous
Did you try the Forgot Password link there? https://selfserve.publicmobile.ca/forgot-password/
Try it with any email you have, once you got the correct one, you will have to answer a security question,
if you are unable to reset password that way, open a ticket with PM Support by direct messaging and have them to verify
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
02-17-2022 04:34 PM
02-17-2022 04:31 PM
@Samsidhu : Did you activate in a store? Have you actually activated an account yet? Are your services working?
02-17-2022 04:27 PM
02-17-2022 04:26 PM
@Samsidhu Are you trying to setup PM's My Account access? Where you put in the number to verification code?
02-17-2022 04:23 PM
When i put my number to verification code it says invalid
02-17-2022 04:21 PM
@Samsidhu Do you mind to provide more info? Like you just joined and you got this when people call your new number?
or you got this when you dial out?
did you try a reboot?
give us more information...
