02-14-2021 11:39 AM - edited 01-05-2022 05:16 PM
When I try to listen to my voicemail I get a invalid MMI code. How do I get rid of it. I asked a moderator and he told me to post it, so I have.
Joining Public
02-14-2021 12:14 PM - edited 02-14-2021 12:16 PM
@thepennh wrote:When I try to listen to my voicemail I get a invalid MMI code. How do I get rid of it. I asked a moderator and he told me to post it, so I have.
Try manually entering your default voicemail number registered in your phone (should be under your phone's app voicemail settings) to:
1 - (your area code) - 580- 4001
If that doesn't work, try using a neighboring area code.
02-14-2021 12:06 PM
Here is a thread on the updated voicemail access numbers for each region. Maybe try calling the number for your region.
02-14-2021 12:01 PM - edited 02-14-2021 12:03 PM
@thepennh : You're right. Sorry. Not at you. I was scoffing at the moderators for telling you to come here for help. Why the heck couldn't they bother?
It sounds like your phone needs to have the voicemail access number properly configured for here. There are many across the country but with Canada-wide calling any one will do. But when you call 17785804001 do you get into your voicemail? And you could opt to use that number in the settings.
Edit: I'm guessing you likely have something like #81# (not exact) or something set for voicemail from a different provider.
02-14-2021 11:50 AM
When I press and hold the 1 key I get a message reading invalid MMI code. May I ask why you find this funny.
02-14-2021 11:44 AM
@thepennh : LOL Seriously!? Ok, so...what happens if you dial 17785804001? What happens when you press and hold the 1 key? At what exact point in trying to listen to a voicemail are you getting this message?
