Internet data
melromano03
I am not able to connect to internet and use data when I am away from our home internet.
7 REPLIES 7
@darlicious...iPhone SE...Settings / Cellular / Cellular Data Options / Data Roaming enabled.
I mistakenly thunk that had to do with using data away from wifi. 😎
@melromano03
Knowing the brand and model of your phone would be immensely helpful to us.
I'm pretty sure @hairbag1 meant to say do you have your mobile data toggled on...as roaming has no bearing unless you are in the US and have purchased a roaming add on.
@melromano03  Do you ever able to use Mobile Data? It was working before and just not working today?  or it never work?
Any chance you got a new phone and it only not working on your new phone?
did you check If Mobile Data is set to on or off ? how about Airplane mode?
Incoming calls and outgoing calls both working?
What kind of phone is yours? brand and model?
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
How to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  HERE
click HERE
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
 @melromano03 : Has it ever worked? Can you check your overview page under My Data & Add-ons for a line mentioning data? Or if you know your 4 digit PIN can you check the quantity remaining in the 611 service? And of course turning on the mobile data setting.
@melromano03
More details would be helpful.  Has data worked before?  New customer or old?  Does talk and text work?  Is your account status active or suspended?  Phone model?  More details the better.
Some basic trouble shooting advice:
reboot phone
network reset of phone
check the APN settings
https://www.publicmobile.ca/en/on/get-help/articles/what-you-should-do-after-activating
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
hairbag1
Make sure to enable Data Roaming in the settings of your phone.
