International texts not going out, incoming works fine
01-23-2020 11:28 AM - edited 01-05-2022 09:09 AM
So, after I switched over from my old $33 plan to the $25 I can't send out international texts anymore. Same sending phone & number, same recipient phone & number, messages come in just fine and my phone thinks it's getting the messages out but the recipient is not receiving them. No apps or nothing involved, just plain old text messages. How do I get this fixed?
01-23-2020 07:49 PM
Oh, I lived in Finland for 1 year haha! 😄 I miss Finland now 😄
01-23-2020 12:32 PM - edited 01-23-2020 12:33 PM
@merenze wrote:I'm trying to text Finland. Entering the number manually seems to have no effect.
@merenze Put your phone in airplane mode for 15 minutes turn it back and try sending the text again. If it still doesn't work then:
- Make sure the number is correct maybe your friend changed numbers or their service is down
- Can you try sending an International text to another number? If it works then #1 is the issue.
- If it still a problem then submit a ticket to PM maybe they need to reset your account or in some cases a new sim will be required.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
01-23-2020 12:20 PM
01-23-2020 11:46 AM
You probably done so, but have you rebooted your phone?
01-23-2020 11:30 AM - edited 01-23-2020 11:33 AM
@merenze wrote:So, after I switched over from my old $33 plan to the $25 I can't send out international texts anymore. Same sending phone & number, same recipient phone & number, messages come in just fine and my phone thinks it's getting the messages out but the recipient is not receiving them. No apps or nothing involved, just plain old text messages. How do I get this fixed?
Try entering the number manually. Manually type in the recipient number on your texting app.
Which country are you trying to text?
Use "011" + country code + 10-digit phone number (including area code)
Btw are you able to text to a local Canadian number?
All the current PM plans (that having texting) include International texting.
