06-03-2022 08:53 AM
My plan says International texting, but I can’t send or receive any texts/SMS from Switzerland.
06-03-2022 06:23 PM
Is this a business or personal contact? Or is it a short code? International short codes are hit and miss. If this is the issue and it previously worked with pm then its on the sender's end. They may have changed the short code or its perimeters and it no longer can be recieved as it once was...this is common for short codes from financial institutions, brokerages, investment firms and the like as they have strict security guidelines and policies.
06-03-2022 11:50 AM
No, I’ can’t. I used to be able to receive an SMS from Switzerland for years, but 3 month ago it
stopped working
06-03-2022 10:42 AM
Is your phone an iPhone? Do you have data turned on in your phone?
06-03-2022 10:16 AM - edited 06-03-2022 10:16 AM
@Idieh You can receive local text without problem?
can another friend from another phone in Switzerland tries to text you? Another phone is the key
Similarly , can you text your other friends in Switzerland (those with other numbers)?
Just want to confirm if it is an issue with a single friend (single number) in Switzerland or anyone in Switzerland cannot text you
Check if you accidentally blocked that particular contact
06-03-2022 10:11 AM
no, I’m in Canada and want to receive a text from Switzerland. I used to get it, but since 2 month it doesn’t work anymore
06-03-2022 09:16 AM
So you and your phone are IN Switzerland? You would have no service there as PM only works in Canada or in the USA with appropriate roaming package. That’s it.
06-03-2022 09:08 AM
@Idieh you can only text to other countries from Canada you cannot send any texts from Switzerland with your public sim
06-03-2022 09:02 AM
Can you send and recieve from other european countries?
